Personally I have not used a "copper core" plug in over 20 years. I use precious metal plugs in everything inc OPE and never had a failure. They stress the coils less and fire easier than coppers because of their reduced firing voltage requirement. Anyone want proof try a precious metal in a lawnmower or other OPE engine that is hard to start.
This is a perfect test engine as it uses a magneto ignition that needs cranking speed to generate enough voltage to fire, the precious metal plug fires right up at a lower cranking speed. I told the OPE dealer this and he called B.S to it but tried it anyway, now he is a believer with and has fewer wont start service calls under warranty.
I had a brand new (still have it 10 years later) lawn mower my wife could never start, she couldn't pull it fast enough, I put a platinum in it and she can start it first pull every time. In the snow blower the results were even better. Keep in mind these are the simplest of engines with no ecm and simple carbs so any difference in performance is easy to see.
