Originally Posted by Gebo
I'm not communicating properly. I'm talking about the affect on the electronics prior to the spark plug. I'm not asking about performance or anything mechanical within the engine.
I'm talking about any component before the actual spark plug itself.
Even as far as affecting the wires, could and even computer long term.
Basic attributes of a spark plug (ignoring multiple electrodes for a moment) are: thermal conductivity (heat range), gap, and resistance. Resistance includes the resistor core and the conductivity of the electrodes. (Of course the air gap is resistant as well). Practically speaking, if copper core conventional plugs are fresh, the electrode resistance is close enough and doesn't matter. It is only when they are old and carbonized that it begins to matter, but at that point they should be replaced.
My take on it, on the topic of sensitive engine electronics versus spark plugs, assuming you don't swap in non-resistor for resistor plugs, it all has to do with the gap. Iridium and Platinum plugs typically come with, and are spec'ed for, a large gap that works well with modern high energy ignitions. Putting in a tighter gapped copper/nickle plug might burn out modern electronics due to increased amperage.
Likewise putting a larger gapped Iridium or Platinum plug in an older system would make for a weak spark, and would exhibit the symptoms of a plug with excessive wear (which is to say, excessive gap). The increased long-term conductivity of the precious metal tips is not going to make up for a larger air gap.
There are complications. For example Rock Auto has a graphic they slap in most Spark Plug info screens showing Iridium as always superior to Double Platinum. But this does not match all manufacturer's product positioning. Also product positioning and marketing can be confused as well.
For example NGK's Iridium IX (a very good plug used as OEM by my Honda) is a single Iridium electrode and is sold at a lower price than the Laser Platinum which has both center electrode and tip a precious metal. NGK markets the Laser Platinum as the "OEM Style" and the Iridium IX as "Performance" but the Iridium IX is the actual OEM plug for my Honda Pilot. I put in Iridium IX's 106K miles ago and they worked fine. My mechanic put in Laser Platinum's last week when he did the timing belt and valve adjustment... after two tanks of gas... they work fine, too. Exact same fuel economy as the last 2 tanks on the old 105K+ mile Iridium IX plugs.
Other complications are switching brands, which increases the possibility of resistor core resistance and thermal range changes. Multiple tip plugs that are not OEM specified. Manufacturers changing OEM plugs during an engine lifespan, with or without ignition changes. Differing user experiences with available plugs All enough to fuel the forum wars whenever a new reader asks "what's the best plug for my XXX YYY?"
