Is there any CK-4 oil that's also SP rated?
Yes, There's also more than what's listed that have not yet been tested.Is there any CK-4 oil that's also SP rated?
Yes, There's also more than what's listed on this list that have not yet been tested.
https://bobistheoilguy.com/forums/threads/voa-diesel-oil-database.362789/
Fixed. Thank you!Rotella T4 10w30 is CK4/SN
You're welcome. Yes, I've not seen SP on 5w or 0w-40's for any common CK-4 oils.Thank you. It appears there isn't any 5W-40 or 0W-40 that's CK-4 and SP dual-rated. Is that accurate?
Fixed. Thank you!
the closest you might get is Mobil Delvac 1 5W-40 ESP which is CK-4 and SN
hmmm... its very possible I'm looking at an old website/document. Mobils website is like a labyrinth. This page here does say SN as a "meet or exceed" but its very possible its incorrect.My Delvac 1 esp 5w40 is only CK4
OP looking for CK-4/SP & that product isn't CK-4.My 12 quart bag in box Mobil 1 0w40 is indeed SP rated
The Delvac 1 Truck & SUV 5w-40 is rated below:hmmm... its very possible I'm looking at an old website/document. Mobils website is like a labyrinth. This page here does say SN as a "meet or exceed" but its very possible its incorrect.
https://www.mobil.com/en/lubricants...-lubricants/products/mobil-delvac-1-esp-5w-40
EDIT: even the website "title" is weird and out of date so very possible
I have never heard of Delvac 1 Truck & SUV... do you have any more info on it or any links to any PDS? Thank you!The Delvac 1 Truck & SUV 5w-40 is rated below:
API CK-4, CJ-4, CI-4Plus, CI-4 API SN, CaterpillarECF-2, ECF-3
Understood. ThanksJustin: my Mobil Delvac 1 ESP 5w40 isn’t truck and suv rated.
Their website guy is work from home. Nothings changed since February 2020.hmmm... its very possible I'm looking at an old website/document. Mobils website is like a labyrinth. This page here does say SN as a "meet or exceed" but its very possible its incorrect.
Thanks, this looks like it might be the winner. I do wonder why there aren't any 5W-40 CK-4/SP oils.A closer one is Delo 400 XSP 5w40 which is CK-4/SN+
Certifications and Performance claims would suffer with the lower Phosphorus amount SP requires (0.08% mass max). It would lose Ford F1 Specification as just one example. There are a few 15w40 and 10w30's as show in the database already CK/SP & it must not be a big seller to offer CK-4/SP. However, from what I've seen these oils tend to be just a general multi-fleet HDEO/Gasoline oil & nothing really special. The lower Phos. could help if running it in a gasoline application but there are already 5w-40's for gasoline engines anyways so CK-4 wouldn't be a requirement for that.Thanks, this looks like it might be the winner. I do wonder why there aren't any 5W-40 CK-4/SP oils.
