I agree with every comment.
In a nutshell, oil (as we all know) does not produce soot, but rather helps control it.
The rate of soot production is a function of engine design, fuel used, and type of service. Soot control is a function of the dispersent and detergent portion of the additive packages. So, oil cannot "reduce" soot; it helps deal with it's presence AFTER the creation of it.
Since CJ-4 was desgined to superceed previous versions, and EGR is ever increasing in these coresponding engine designs, then it only stands to reason that CJ-4 will handle soot "better" than previous oils.
2% soot with CJ-4 oil is nothing to be concerned of. As you state, your wear is low and your vis is OK. Keep using the oil.
