Originally Posted By: wirelessF
I read it in a magazine about a Dodge hemi engine that had bent push rods. Now that I checked it again, it had bent push rods dues to valve float from running high RPM's. The article did mention about the high viscosity overfilling the hydralic lifters causing a no start situation, but not bent pushrods.
This was from MOTOR Magazine by the way.
Sounds like junk valve springs to me. Good springs would have prevented both problems
The article also mentioned about a TSB for the weak valve springs in these engines. Did you get to check out the magazine, it's pretty interesting. There is a free digital version http://digital.motormagazine.com/(S(4z1ecjre4tlimius2um0wbq5))/default.aspx?bhcp=1
