Originally Posted By: volodymyr
Thanks for your input. My dilemma is actually very simple. The price difference between A3/B4 and C3 is negligible (1 USD diff per liter) so I want to take the best oil possible.
Overall, I have two hesitations:
1. Since price diff is very small I am choosing between Castrol MAGNATEC 5W-30 C3 and CASTROL
EDGE FST 5W-30. Most of you folks, do tend to suggest me to buy Edge, however I can see that Edge 5W-30 is not Vollsynthetik.
2. I can buy Vollsynthetik Castrol EDGE Titanium FST 0W-30 however this is not 5W-30, but 0W-30. And most of you say that since Nissan recommends 5W-30 I should stick with it.
Which one is better? Following Nissan's recommendation and using 5W-30 or buying Titanium FST Vollsynthetik but 0W-30?
As I stated above, a 0W-xx oil will satisfy all of the requirements of a 5W-xx oil with the exception that you will get better extreme cold weather performance. Although I understand your concern with respect to the recommended grade that Nissan specifies, but considering that your warranty is up and there are no "legal" issues to deal with, a 0W oil will perform just as well as a 5W oil in your engine and application. Not that it is necessary, but you don't need to avoid it just because it is not explicitly stated in the manual.
Also, regarding A3 and C3 oils, there has been some discussion recently that a higher-SAPS oil (such as A3) does indeed offer better protection than lower-SAPS oils (C3) when they are allowed to be used. This is not my information, so don't shoot the messenger. Take it with a grain of salt
So in other words, since your car does not require a C3 oil exclusively, if it were me, I'd be buying only A3/B4 oils for it if I could.
