chlorinated paraffin's
S California
What ever happened to all the additives with chlorinated paraffin's? These additives were supposed to save the world and cure all automotive engine problems and make every engine a hyper miler. When you were younger and foolish and had yet to discover BITOG and see the light, did you every pour one of these additives in your engine?
I used ER (Energy Release) years ago, and still have 1 gallon in my kitchen. Mainly used in old cast iron engines; I have not used it since my BITOG indoctrination. In fact I believe my first post on BITOG was about ER.
if memory serves right i was told that when you use chlorinated paraffin's if something goes wrong , it goes wrong in a BIG way. now not being a expert iam not sure what that means.
Originally Posted By: JHZR2
Isnt there a tad in MMO?
True, there is in Aussie "Penetrene" too, and I use that...not like you use MMO 'though.
There's 3/4 of 1% of a combination of ortho- and para-dichlorobenzene in MMO. From what I have read, benzene is an aromatic hydrocarbon, and not a paraffin hydrocarbon, so the content of MMO is not chlorinated paraffin.
Here's what is on the MMO board about this topic. My buddy AD asked the question, since he and I have been exchanging emails about it. Hopefully one of their tech guys weighs in.
One of our Bitog members posted this over on the MMO forum. I pasted this:
Also note that since I put this together, I have found out the Phosphorous is Tricresyl Phosphate, an organophosphate - a very, very good AW/EP additive.
See the link below for details:
http://en.wikipedia.org/wiki/Tricresyl_phosphate
There have been many studies on the effectiveness of TCP, and I have not found anything that surpasses it in EP friction reduction and anti-wear - and it is very complementary to ZDDP as it works in the higher temp range where ZDDP fails.
It is also very good at cleaning up varnish (in addition the to mineral spirits)
TCP is what gives MMO the lead scavenging, not the dichlorobenzenes. Also note the link below - that it is stated that the TCP (organophosphates) is the main ingredient that prevents corrosion from chlorinated hydrocarbons (dichlorobenzenes) as noted below.
“Oil-soluble organophosphates, with or without zinc, have excellent high-pressure and antiwear properties, and provide corrosion protection especially in presence of chlorinated hydrocarbons. ZDDP starts decomposing at 130-170 °C, while the activation temperature of TCP typically exceeds 200 °C. Their reaction products form a chemically bonded lubricating film on the surfaces.”
http://en.wikipedia.org/wiki/EP_additive
Also note that the version used today has reduced the “o-” part of the tricresyl to eliminate the neurotoxicity, otherwise it would have to be listed in the MSDS.
