Originally Posted By: jerre310
So, what can I expect for gas mileage?
06 Express HD 3500 cargo van, 6.0, rear axle 3.73 ratio, white paint, round tires!
Will be hauling about 30 case of oil at all times. I will also haul up to 60-70 cases plus 55 gallon drums, and pull a 10' trailer with a load of oil once a month.
All fluids and filters will be Amsoil.
We've got an 08 Savanna HD XL, 6.0, 3.73 rear end with 10k miles on it right now. Was getting 13-13.5 mixed driving, and now it's dropped to 12.5-13 for some reason. I've lowered the air pressure in the tires from 70 psi down to 60 due to uneven tire wear (center). I just had the rear diff fluid changed using amsoil SG 75w90 from my mechanic for $50 labor only. I hope like [censored] he in fact used the amsoil and didn't stash it and use another dino. I'll be [censored] off big time.
Oh, btw....the 6.0 loves the ASL/EAO50 combo. Cold start noises dissappeared when we switched, and even runs quieter when warm.
I think the only difference between the 3500 and 2500 is one extra leaf spring is all. I think so anyway.
I'd really like to weigh our van; it sure does seem like a dog for power until you get into the r's a bit. Mid and high rpm's are descent, but low sucks big time. I do not like the way the trans shifts when accelerating. It seems like you have to floor it before it will down shift. Other than that, it's been a good van so far.
