Hey guys please look at my sheets and tell me what you think!! I have way too much of this oil and need to sell some off. It is for sale in the area marked "For sale" in the forums. Please email or post your thoughts.
DEAN MACHINERY CO - MISC
PHONE:
COMPANY NAME : DEAN MACHINERY CO.
FLUID BRAND/WEIGHT :
SHOP JOB NUM :
EXT WARR EXPIRE DATE :
COMPARTMENT MODEL :
COMP MANUFACTURER :
SAMPLE TYPE: OIL 901
FLUID TYPE :
FUEL CONSUMED :
LAB CONTROL NUMBER SAMPLE DATE PROCESS DATE EQUIPMENT METER METER ON FLUID FLUID CHANGED MAKE UP FLUID MAKE UP FLUID UNITS FILTER CHANGED
E100-40225-0072 8/13/10
No Action Required IS THIS NEW OIL FROM A DRUM, TANKER OR COMPARTMENT. ON TICKET THERE WAS NO INDICATION. VISCOSITY INDICATES A 30 WT OIL.
8/13/10 Unknown Unknown
Cu Fe Cr Al Pb Sn Si Na K B Mo Ni Ag Ti V Mn Ca Mg Zn P Ba
E100-40225-0072 0 0 0 1 1 0 4 0 0 270 74 0 6 0 0 0 1944 42 1206 973 0
W A F V100 PQI ISO 4μ 6μ 10μ 14μ 18μ 21μ 38μ 50μ
E100-40225-0072 N N N 10.5 6 22/19/14 27936 3089 234 98 51 35 8 4
Wear Metals (ppm)
Oil Condition /
Particle Count (ct/ml)
Ag = Silver, Al = Aluminum, B = Boron, Ca = Calcium, Cr = Chromium, Cu = Copper, Fe = Iron, P = Phosphorus, K = Potassium, Mg = Magnesium, Mo = Molybdenum, Na = Sodium, Ni = Nickel, Pb = Lead, Si = Silicon, Sn = Tin,
V = Vanadium, Zn = Zinc, A = Antifreeze, F = Fuel, W = Water, P = Positive, N = Negative, T = Trace, E = Excessive, NIT = Nitration, OXI = Oxidation, ST = Soot, SUL = Sulfation, ISO = ISO Rating, PFC = Percent Fuel Content,
PQI = Particle Quantifying index , NaW = Salt Water, FL Pt = Flash Point, TAN = Total Acid Number, TBN = Total Base Number, H2O = Karl Fisher result, V100 = Viscosity@100C, V40 = Viscosity@40C
Notice: This analysis is intended as an aid in predicting mechanical wear. No guarantee, expressed or implied, is made against failure of this piece of equipment or a component thereof
FAX:
CUSTOMER EQUIP NUM :
JOB SITE :
MANUFACTURER :
MODEL :
SERIAL NUMBER :
COMPARTMENT NAME :
SAMPLE LABEL NUM :
EXT WARR NUMBER :
MIKE MCCONNELL COMP SERIAL NUM :
NEW OIL
Fluids
MCCONNELL-903
NEW
5701 E 87th St
816-753-5300
www.deancat.com
Kansas City, MO 64132
Misc Account
PHONE:
SHOP JOB NUM :
COMPARTMENT MODEL :
COMP MANUFACTURER :
SAMPLE TYPE: OIL
FLUID TYPE :
FUEL CONSUMED :
E100-40230-0047 8/18/10
No Action Required NORMAL WEAR METAL READINGS. VISCOSITY IS IN 40WT RANGE. MORE SAMPLE HISTORY NEEDED TO ESTABLISH A NORMAL WEAR TREND. CONTINUE NORMALLY SCHEDULED SAMPLING.
8/18/10 Unknown
E100-40230-0047 0 3 1 1 0 0 4 0 4 231 82 0 0 0 1 1 2032 51 1764 1385 0
W A V100 PQI ISO 4μ 6μ 10μ 14μ 18μ 21μ 38μ 50μ
E100-40230-0047 N N 13.2 4 22/19/14 32668 3074 287 106 51 29 5 3
Wear Metals (ppm)
Oil Condition /
Notice: This analysis is intended as an aid in predicting mechanical wear. No guarantee, expressed or implied, is made against failure of this piece of equipment or a component thereof.
PHONE:
SHOP JOB NUM :
COMPARTMENT MODEL :
COMP MANUFACTURER :
SAMPLE TYPE: OIL 902
FLUID TYPE :
FUEL CONSUMED :
E100-40225-0073 8/13/10
No Action Required IS THIS NEW OIL FROM A DRUM, TANKER OR COMPARTMENT. ON TICKET THERE WAS NO INDICATION. VISCOSITY INDICATES A 20 WT OIL.
8/13/10 Unknown
E100-40225-0073 0 0 0 1 0 0 3 0 0 294 74 0 0 0 0 0 1931 45 1184 966 0
E100-40225-0073 N N N 7.5 2 21/18/13 16809 1616 136 55 31 22 6 3
Wear Metals (ppm)
Oil Condition /
Sample Identification Number
Identification Written on MSDS
Minimum spec for KV at 100 C
Cranking Viscosity (mPa.s @ C)
KV @ 40 C
KV @ 100 C
Viscosity Index
Comment
901
5W-30
3.8
6600 @ -30
59.76
10.59
170
Synthetic Blend Motor Oil
902
0W-10
3.8
6200 @ -35
38.4
7.8
180
903
15W-40
5.6
7000 @ -20
81.95
13.49
169
912
5W-30
3.8
6600 @ -30
43.26
8.53
180
912 I still need to post. Please email me!
PHONE:
SHOP JOB NUM :
COMPARTMENT MODEL :
COMP MANUFACTURER :
FLUID TYPE :
FUEL CONSUMED :
Wear Metals (ppm)
Oil Condition /
FAX:
JOB SITE :
MANUFACTURER :
MODEL :
SERIAL NUMBER :
COMPARTMENT NAME :
SAMPLE LABEL NUM :
EXT WARR NUMBER :
NEW OIL
Fluids
MCCONNELL-903
NEW
5701 E 87th St
816-753-5300
www.deancat.com
Misc Account
PHONE:
SHOP JOB NUM :
COMPARTMENT MODEL :
COMP MANUFACTURER :
SAMPLE TYPE: OIL
FLUID TYPE :
FUEL CONSUMED :
8/18/10 Unknown
Wear Metals (ppm)
Oil Condition /
PHONE:
SHOP JOB NUM :
COMPARTMENT MODEL :
COMP MANUFACTURER :
FLUID TYPE :
FUEL CONSUMED :
8/13/10 Unknown
Wear Metals (ppm)
Oil Condition /
KV @ 40 C
KV @ 100 C
Viscosity Index
Comment
901
5W-30
3.8
6600 @ -30
59.76
10.59
170
902
0W-10
3.8
6200 @ -35
38.4
7.8
180
903
15W-40
5.6
7000 @ -20
81.95
13.49
169
912
5W-30
3.8
6600 @ -30
43.26
8.53
180
