Cherokee 4x4
Vermont
I recently picked up a '96 Jeep Cherokee 4x4 that my wife and I plan to use as a winter beater in a couple of years when we move to new england. The car was owned by an elderly guy and he seems to have taken really good care of it and it has 156000 miles on it with the 4.0. It has a small oil drip which I believe is coming from the rear main seal and I was thinking about using Maxlife conventional 10w-40 while we are still in Florida. I am not really interested in going to synthetic in this vehicle since it will not get a lot of miles and the oil will probably be changed annually with 3-5 thousand miles on the oil.
This is my first 4x4 so I need to learn about the care and feeding of the transfer case as well.
Thoughts?
A little OT, but if you don't mind me asking can you give me an idea of what you paid for that? Via PM is fine. I'm toying around with replacing my beater with a 4X4, and either an Explorer or Cherokee that age would fit the bill nicely.
While my Aerostar runs very well it is absolute garbage in the snow!
Thanks
Not at all. I paid $2200.
Being in FLA, maybe 4x4 are in less demand. That Jeep in Ohio would still get 3-4,000 and it would have some rust on it. You got a great deal on a really clean truck.
I think either or Pennzoil High Mileage Maxlife in the 5w30 through 10w40 would be a good oil for trying to stop that oil drip in Florida. In New England I'd use a 5wXX personally.
Another good one would be Rotella T6 5w40.
If I remember correctly these take ATF +4 and will run for almost ever.
You got an EXCELLENT vehicle there. I picked up a used '99 Cherokee for my daughter and fell in love with it while she was learning to drive. When I handed her the keys, I went out and found a 2001 for myself. Hers is a 5-speed 4x4 2-door, so its actually more desirable than my 4-dr automatic 2-wheel drive, but the 01 is optioned up better. I paid 3k for each of them- Cherokees are a great used car bargain, and since the drivetrains are rock solid to 300k miles and beyond even with half-decent care, its even better.
Using Maxlife is a good choice. Slow leakage from the rear main seal is common on the 4.0, and it won't get worse quickly or turn to a gusher... it just kinda dribbles. Also the valve cover gasket is probably contributing at that mileage, and the oil filter right-angle adaptor O-ring might be as well. The valve cover gasket is easy, the filter adaptor a little harder (you have to get a big honkin Torx socket after it), but doesn't require engine removal. I run Rotella T6 in both my daughter's and mine, and they both turn in great used oil analysis, and don't consume measurable amounts of oil over 6000-mile change intervals.
You've either got an NP231 transfer case (part time, shift pattern2-4hi-N-4Low on the shifter) or an NP242 (full-time Shift pattern: 2WD - 4parttime - 4fulltime - N - 4LO). Both of them use plain automatic transmission fluid-Dexron III or ATF+4- same as the Asin AW-4 automatic its got. (edit- I can see from your photos that you have the NP242- leave it in 4Fulltime in icy/snowy conditions and you'll be good. 4Parttime locks the center differential and is better for mud or hard offroading, but on snow/ice it will make it hard to turn corners and is damaging to use on dry or simply wet pavement)
The only thing I would encourage is that you NOT use such a nice and capable vehicle up as a "winter beater" (although it will serve well in winter, especially if it has the NP242 case). I'd sacrifice the Civic to the rust gods if it were my choice ;-)
good price, good vehicle, chassis stronger than most people think.
just change the oil at times and leave the xfer case alone unless it makes noises at you
That's clean. Don't beat it too hard. I'd daily drive that. Or sell it when you get up here. Around here 3~4 grand doesn't seem to hard to get for something in that shape.
That is gorgeous! I paid 4K for my '98 Sport 2WD in 2002. Mine did not look near as good as that. You have a nice vehicle on your hands, change out the fluids, (I would do 'em all with the price you got it for) and that thing will go for ever. I miss mine I traded it in towards an Altima, I like the Nissan but I miss my beater jeep to go fishing in and not worry about getting it dirty. GREAT FIND. CHANGE THE FLUIDS!
i have a 1999 cherokee classic. 4 years ago my rear main was seeping a little. i used maxlife 10w-40 and it sealed it up for the last 4 years. still dry! mike
Looks like an excellent find. A vehcile like that would have fetched more up here considering the lack of rust. Very nice! My '88 Cherokee is starting to show a bit of rust but it lived in Colorado until 2002.
On the oil drip, as was pointed out, three potential culprits, all common. Rear main seal (still not leaking on my '88), Valve cover gasket (replaced on mine) and the O-ring gaskets in the oil filter adaptor (replaced on mine). The valve cover gasket is an easy one, and the oil filter adaptor was easy on mine (still had a hex head) but I understand the big torx fastener they switched to is a bear to get removed. The rear main seal is one to tolerate until it weeps too much, and then do it. It can be done in the vehicle without dropping the transmission, though it is called one of the dirtiest jobs to do on a Cherokee!
Other than that, flush the fluids that you don't know about. Original spec on the transmission and transfer cases was Dexron/Mercon, and Chrysler back speced that to ATF+4. My choice is to keep using the Dex/Mercon, noting that it wasn't until well after the Cherokee went out of production that the use of ATF+4 was allowed.
10w40 should work fine in Florida. 10w30 or 5w40 are also good choices.
Enjoy the Cherokee! We love ours.
Thanks for the replies!
Valvoline Maxlife it is then. This seems to be a much-loved vehicle and I am happy with it so far.
It's got Selec-Trac (NV242 t-case) which is a nice setup. Any ATF should do fine for the t-case, and some say 5w30 engine oil works nicely too, although it has to be changed more often. Any Dex/Merc will do for the transmission.
MNgopher's got the oil leak spots covered.
As far as oil, Rotella T6 works nicely, as would 10w30 T5 in the 4.0. For 6 - 7k or less per year, I'd just run T6 and change it in the spring every year. My Mom's 4.0 WJ (99 Grand Cherokee) gets the same treatment as my Jeep, T6 and a pureone every 5k, and it's running great, although only at 96k miles.
EDIT: Oh yeah, forgot about filters. The standard filter is a Puro L14670 size. However, the larger Puro L30001 (Motorcraft FL-1A) fits just fine, and at least for the purolators, is the same price.
