quote:
Originally posted by mdocod:
i think it has been determined, that 5w20 oil is potencially better for some engines... the faster flow results in better cooling effect, and it keeps engines cleaner because of that faster flow. Heavier oils are used in engines that need higher pressure or extreme film strength- but then again, a 5w20 synthetic has more film strength than a 20w50 conventional anyways, so you can get the best of both worlds if you don't need higher pressure.
I read an article- can't remember the link.. a guy wrote a guide to engine oils... most of the article explained why thin is better, and that we shouldn't be worried about oil thinning when it gets hot, but rather, thickening when it cools. That flow is what provides lubrication, not thickness.
consider the following, if the 20 weight oil flows better, and helps move heat around better, than the average oil temp could be a little lower, slightly lower oil temps result in slightly thicker oil anyways. so the 5w20 doesn't run as thin as one might think.
I wouldn't hesitate to run 5w20 or 0w20 in my car, even though it calls for 5w30... heck, the manufacure even recomended 5w20 synthetic for my engine in a TSB to help resolve flow issues to the valvetrane. The result for many experimenters on this engine with 5w20, has been good. (3.2L V6 isuzu, 24valve, SOHC)
