Originally Posted by ram_man
Originally Posted by edyvw
https://stlouis.craigslist.org/cto/d/saint-louis-passat-18t-manual/6822129445.html
Opinions on this Passat please
Here's a rather amusing thread on that engine:
https://www.ericthecarguy.com/kunen...ailures/59539-audi-vw-1-8t-engine-sludge
Had that car with that engine.
Two things:
1. It is prone to sludge, BUT only in the US and primarily pre-2001 models.
VW wanted to simplify maintenance, so they told owners: use any oil as long as it is 5W30, 10W30 or 5W40. No indication whether it should be synthetic or not. At the same time, they told European owners that they MUST use VW502.00 oil which is by default 0/5W40 (or rarely 10W40) or thick 0/5W30 (HTHS above 3.5).
In 2001 VW/Audi issued bulletin to US dealerships: Only VW502.00 to be used with larger oil filter.
That is B5.5 version which means it suppose to have steady diet of VW502.00 oil. One might say any synthetic: Nope, my friends Audi A4 bombed at 80k with diet of Mobil 1 5W30 that you can get in Wal mart.
My experience was: I got one with 40k. Used strictly German Castrol 0W30 (back in the days when it was green, and then moved to amber color). Occasionally I would try Mobil 1 0W40 (noisier), Castrol 5W40 (lifter noise after 4k, due to oil) or Pennzoil Ultra 5W40. I traded in car for VW cc with some 110k, and engine was in pristine condition. No single trace of sludge.
2. Chain. That engine has belt and chain in the back. Chain will start to rattle, but it is not uber expensive.
That Passat is probably best made Passat ever. It has longitudinal engine and it is basically Audi underneath. It is super solid car, and 1.8T is better choice than 2.8 V6. If you can find one in good condition, get it.
Is there anything I should look for or be aware of if I look at it? Anything to consider?
Take it to good VW indy mechanic and pay him to check car.
I mean, if it is automatic transmission, while very good on these Passat's, like in any car, they can fail.
Cold start rattling in the back of the engine: chain.
Any service records? These need timing belt replacement, preferably every 90k.
If you never had VW, take it to indy mechanic and pay for check up. You will not be able to check car by asking internet people to do it.
