I've been using these reels for a few years because its the best way for me to handle 100' extension cords. The only problem is they're light and not the easiest to handle. I decided I wanted to get a reel I could mount on the wall but they are very expensive for a decent one and the bigger problem is I can't be tethered to one outlet, I have to move the cord from the garage to the front of the house to finish trimming and blowing off the front drive and walk. So this is what I came up with.
I also wanted to be able to remove the whole reel in case I needed to take it somewhere. As you can see I have it secured up against the stud with a hose clamp that holds it steady. Remove the hose clamp and it slides right off.
Was hoping this might give some of you ideas and maybe even some suggestions to improve it a little bit. So far its been working great.
Cost: $10 for the reel and $4 for the conduit and clamps. Hose clamp I had laying around.
