Cheap air filter regrets :(
UK
serviced someones car than they bought their own parts. original air filter in the car is the orange MANN filter , replacement a cheapo crosslands filter from eurocarparts.
pictures say it all.
new filter will work fine. old filter is just better. even has that foam thing on the old filter forgot what its advantage was.
A cheap air filter that wasn't all that cheap (Napa Pro Select) ruined the MAF sensor on my 2019 Pathfinder. I didn't realize it for many miles, but it didn't fit quite right in the air cleaner housing, allowing unfiltered air to pass. I cant say the OEM sensor is for sure ruined, but it won't work as-is and I haven't attempted to clean it. It's a weird cartridge style. All my local Napa carries for this application is the same pro select filter so I had to go elsewhere.
I often bring in parts for a indy shop to use but my parts are almost always better quality that what they can get quickly from NAPA. I am not looking to save money on the parts by getting them myself, but rather decide what quality of parts are used in my car.
Had Crosstrek at shop last week, needed a new rear wheel bearing. I did not want a Chinese one from NAPA (I am assuming that is what it would have been) so I supplied an OEM one from Subaru. The mechanic probably could have gotten one from Subaru himself but might have had to wait for it to be delivered.
It prevents snow from soaking into the cellulose air filter, also acts as a pre-filter.
before the cold weather filter, cars had a screen at the front of the airbox intake duct, which the screen will get clogged up with dirt, which then forces a trap door open to bypass the screen.
Or, in the case of my Phaeton, the snow screens get blocked and both restriction gauges max out because there is no bypass door.
