Originally Posted By: SteveSRT8
Originally Posted By: 4ever4d
I know there is a substantial difference between the SRT and a traditional hemi enine but i wonder how the Pennzoil Ultra 0w-40 would perform in an engine designed for 5w-20?
Actually while there are many differences none of them are major at all.
Go here:
www.allpar.com and read about them, they're just 'hopped up' regular hemis. All the standard hop ups like bigger cam, bigger valves, different intake, etc. coupled with sharper programming, etc.
And as a mod at 300cforums.com I can tell you that since 2005 we have been running all different weights in all the new gen Hemis and have never had a problem with ANY oil.
They are simply not particular about oil choice at all.
Steve I understand the point you're making, but the advantage of the PU 0W-40 (or even PU 5W-40 or M1 0W-40) is to deal with the very real possibility of oil temp's as high as 300F in a track driven SRT.
The same vehicle running a 20wt oil driven on the street where oil temp's likely won't even see 250F is actually running an oil with an operational viscosity higher than what's seen on the track with the higher grade oil.
