Loose connections would be the other issue. The recommended Hubbell receptacle uses a hex head for the lugs, which precludes using any old crappy screwdriver laying around to make the connections.
I have an ECX bit for my screwdriver. This allows me to put enough torque on a regular receptacle to strip out the screw threads. You aren't doing that with a regular Phillips. (You might strip out the screw head, though).
Loose connections would result in heating. Charge the vehicle for 10 minutes, disconnect, check the plug blades to see if they're excessively hot.
I did a bit more research about this and why the common Leviton 14-50R gets so many warnings. The wires go straight in the back and are connected by Phillips/flat head screws that are supposed to be torqued to 25 in-lbs. Hubbell and Bryant have the wire going down the bottom but with the hex head pressing against a wedge and torqued to 75 in-lbs.
I had a look at the Leviton, and it gets some criticism because the internal contacts are fairly shallow, maybe half the depth of the plug blades. Bryant/Hubbell supposedly have deeper contacts, but also can be a pain to insert and remove because it requires more force. However, Leviton has a supposed “EV quality” 14-50R now with hex heads, bigger contacts, different materials, and approval for frequent insertions.
![store.leviton.com](http://store.leviton.com/cdn/shop/files/1450R---Side_1_1024x1024.jpg?v=1706287666)
50 Amp EV Charging Receptacle/Outlet, Heavy Duty, 1450R
Designed specifically for plug-in EV charging applications, Designed to sustain the necessary extended charge time and high frequency of insertions EV chargers require. Perfect option for homeowners who prefer a plug-in EV charging units as opposed to a hardwire application Built of durable...
![store.leviton.com](https://store.leviton.com/cdn/shop/t/4/assets/favicon.png?v=34274907520737093221460996507)
I also decided to check on my parents garage setup with the basic Leviton 14-50R. They’re not concerned that this is a fire hazard, but I wanted to double check. I turned the breakers off and had a look myself. I guess the concern is that the connection can be poor over time if stranded wire splays out past the screws. I also tried to retorque the screws, where some of them could be tightened a bit more. So hopefully this helps, since I heard loose contacts have been blamed for overheating due to increased resistance. This is semi-permanent so perhaps the worries about plugging and unplugging aren’t an issue.
I’m thinking of just changing this out myself even if my parents think it’s OK. I don't think a Hubbell or Bryant would be a direct replacement though as I saw some photos showing that the mounting holes are wider and probably also the faceplate screw holes.
