Charging a sealed refrigerant system in dehumidifier
Near the beach in Delaware
I watched a YT video where the guy attached a self tapping valve to the PROCESS refrigerant line in a refrigerator and with a gauge set and can of refrigerant he added 7+ ounces of refrigerant to the refrigerator after pulling a vacuum.
In my case my dehumidifier works but the system must be a tad low. The display shows air entering at 76F vs air next to the cold line at 70F and it's 6F difference and the difference should be 10F or more, so system is working but not perfectly.
Not looking to toss a $1500 dehumidifier because it's a little low on refrigerant.
My total knowledge in this area is one YT video.
I assume you leave the self taping valve on the refrigerator after you are done.
A $1500 dehumidifier?
I'd imagine one in that price range is serviceable, unlike standard residential units.
What refrigerant would be in it if manufacturered 2018 to 2020?
Probably R134A, R12 was bye-bye by then. The way I do it is put on the tap valve, recover the refrigerant, silver braze on a new low side fitting, pull a vacuum, suck a little refrigerant dye in, and recharge it (by weight, it'll be on the data plate somewhere. Disclaimer-I do this for a living...
