Charcoal in a wood stove
Rochester, NY
I've been curious for a while how it would work to burn charcoal in a wood stove.
In reading on the Internet, the two most common comments I've come across are, "You'll get CO poisoning" and "it'll get too hot and melt your stove." The first is pretty silly, since the fumes will obviously be vented out the chimney. The second I wasn't too worried about since the inside of my stove is mostly firebrick and cast iron.
So, for science, I decided to try. I got a 10-lb bag of 100% hardwood lump charcoal, which set me back $5.50.
The results were pretty underwhelming. It burnt, and kept the house warm, and didn't melt my stove, and we didn't die of CO poisoning. The 10-lb bag lasted about 6 hours. Toward the end the heat output was actually decreasing even though I had the air wide open - I think the ash was accumulating and slowing the combustion.
You can burn coal in a wooden stove all you like. I have a friend that gets large chunks (the size of o shoe box and bigger) of peat and lignite for free and he's been burning that stuff without a problem for about 40 years now
The only problem is sometimes depending on the atmospheric conditions you will kinda stink the whole neighborhood
Charcoal is just preburned wood, I have tossed a bag in the fireplace when I let my fire wood get wet.
