I've got a mildly built Ford 302 that I have been operating recently in ambient temperatures of 100*+. This is a 1969 block and low end. The engine has been heating up and I've noticed that the oil pressure is dropping off as this happens. I rebuilt the engine 49K miles ago and have been using Castrol 10w30 in it since. The pressure starts at a high level because I installed a high volume oil pump when I rebuilt it, but starts to drop off when the engine gets into the middle range of my stock Ford "L-H" temperature gauge. With the pressure slacking at higher temps I am considering raising the oil viscosity to 10W-40 or 20W-50 Castrol. Would this be a recommended step or should I be worrying about the bearing clearances at this point. I'd hate to think that the rebuild lasted less than 100K miles, but I do have lower gears in the rear end and this could contribute to a higher level of bearing wear.
