- Joined
- Jun 24, 2026
- Messages
- 13
Hello all, I have a 2015 F150 5.0 (Gen 2 coyote v8 engine) that I purchased not long ago. Very very long story short...I eventually found out that the engine was sludged. Extremely sludged. So I decided to dismantle the engine and clean it by hand, replace any parts needed, and reassemble it. I'm just a couple weeks away from having it reassembled and running again. Over 90% of the sludge is gone, and there are only a few really small places/corner that have a little sludge residue left. Ford originally called for 5W-20 in this engine...but then due to common oil pressure/viscosity related issues with VCT solenoids & cam phasers, ford later officially supported anything between 5W-20 and 5W-50. Many ford 5.0 owners that have switched away from 5W-20 to higher viscosities such as 5W-50 say that their truck has never ran better...and especially in hot weather climates.
I originally planning on refilling the newly rebuilt engine with Valvoline Restore and Protect 5W-30 in order to help continue the internal cleaning process. However after more research I'd really like to run 5W-50 in the engine due to the way the higher viscosity affects the timing components, and due to its additional protective nature in hot weather...as I live in south Texas where its regularly 95-100 degrees with 85% humidity for many months (tropical environment)...and mild winters that sit between 30-70 degrees and only last for a few months.
Here's my thought/question: Would it be ok to use a Amsoil 5w-50 during the summer months (to protect engine wear with the hot weather, to help timing components operate better)...then switch to Valvoline Restore and Protect 5w-30 during the winter months (to help continue cleaning)? Would changing brands & viscosities cause any problems?
I wish Valvoline made a Valvoline Restore and Protect in 5W-50...but they don't.
Thanks!
Thanks!
