When changing atf fluid, I messed up and had the wrong torque written down for the drain plug and messed up the pan threads. So I am replacing pan and gasket with new ones. This is on an 07 Tundra 50k miles. I now know drain plug bolt is 15 ft lbs. The gasket is heavy duty, see picture. I have never done this before, have read I need to torque bolts in criss cross pattern. The only torque specs for pan bolts I found online (not from Toyota directly so not sure if it is correct) is 8 ft lbs. I was going to use my torque wrench to loosen current bolts by starting out low and increase torque until they loosened to find out current torque. I will clean magnets and put on new pan. Is there anything else I should know or be aware of when changing gasket, obviously make sure everything is clean, maybe clean trans metal mounting surface with brake cleaner? I am debating on whether or not to change strainer also since I am already this far (I would use torque wrench same way to find current torque)....thanks
