Originally Posted by Patman
Here's the thing with this study that bothers me. That "aged oil" that supposedly shows lower engine wear, is also going to have contamination in it, especially direct injected applications that are dumping more fuel into it. So why would we want to leave our oil in longer when that's going on? Also, you can't possibly get every last drop of old oil out when you change it, there could be 10-15% of your total capacity left behind no matter how long you leave the drain plug off. I know with my Corvette, the manual says the capacity is 7 quarts, but when I refill it, the dipstick shows full with only 6 quarts added. So a lot is being left behind (I have seen pics of the oil pan and I believe a good half quart gets stuck in there alone) So my thought is that if the old oil helps "reactivate" the new oil, we don't really need to do anything different than we're already doing, as you'll always have that little bit of old oil doing it's job.
I agree. Like anything else, moderation. There is a sweet spot you can sometimes identify via a used oil analysis with a particular oil/engine that you can go by.
