Changing Coolant Corolla
USA
Hitting 100K in the Corolla and manual mentions coolant exchange. Is it as simple as my early 2000's Civic? Unscrew the petcock with pan under, let it drain, a cold beverage number of minutes later pull radiator cap, drain expansion tank if it didn't already, put petcock back in, funnel-fill with red coolant until full, idle and top up for 20-30 minutes until it stops dropping with heat on full hot, take for a fun drive to get it nice and warm, let it cool for a few hours (overnight?) and check in the morning and top up as necessary?
Dealer wants a tiny bit less than $200. Is this all they'll do? Or do they put gold in it or something? I'm thinking for $20-35 I can do it myself. I know some vehicles they recommend pulling plugs on the engine to get it out of the block and such.
Anyone have $0.02 ($0.08 with inflation now) ideas, advice, opinions?
Check under the hood, mine has a sticker on it saying it needs a vacuum to properly change. I think yours might too, as it seems like it'd be a similar model.
So no, apparently not as simple as drain and refill. :( Makes me sad, but I get it, they have a high spot in the system. Still a pain (for someone who hasn't had to do that before).
What year is your Corolla? Edit: Looks like you have a 2021. I think the stuff I've been reading says after 2019 they got more complicated. Maybe your 2021 is different. I don't see anything about a vacuum on any stickers. Is it under the actual hood of the car? I just have one with other random info, nothing about coolant that I saw.
The car takes the pink super long life coolant not the Toyota red.
I have a gallon from the dealer. Been using it to top off about a cup or two per year. I have the part number from online.
All the parts places (NAPA, Oreillys, etc.) say Asian red coolants in whatever brand are what I should buy.
Is that wrong if I go aftermarket?
Yeah there's a sticker under the hood of my car.
Ok, maybe I'm wrong, I thought Toyota was using the same engine etc--they tend to find something and then not change it for 10 plus years, lol.
If I decide to tackle it myself, I guess I'll find out soon enough 🤣
YouTube has videos and the parts match mine, visually at least, exactly. And it looks like a simple job. If not, AAA can get it to the dealer 😎
On my camry, I needed to remove some of the plastic cover to access the peacock and I needed a short length of silicone tubing attched to the petcock nipple to control the flow into a waste container.
If you're doing it as a professional, you only get one crack at filling the system. So you might need a special funnel or fancy system. I used a regular old funnel and it took 3 or 4 topoffs over 3 or 4 days to get the system full.
