A technical bulletin on QuakerState site said:
"Another phenomenon sometimes observed is a marked increase in oil consumption after changing brands of motor oil. This phenomenon has been occurring for years and can occur when changing from one brand to another within a given company as well as from one company to another.
Generally, when such a change is made, increased oil consumption is observed for a short period of time (one or two oil change intervals) and then returns to the previous low level. Interestingly enough, if one then returns to the original brand, higher oil consumption is again observed.
It has been theorized that this phenomenon is due to a change in detergent/dispersant chemistry which tends to remove previously deposited material which is helping to seal. After this deposit is removed, the new chemistry will produce a deposit which, upon reaching equilibrium, regains full sealing benefits and controls oil consumption to the original lower level."
What do you think & what are these "deposits" ?
