There are no clutches or frictive debris in an engine. I get your point on fresh fluid, but it’s best to be careful. Can you change all of it out? Sure. But just like has been discussed numerous times in the HPL Engine Cleaner threads, if you’re going whole-hog to change the fluid and correct past maintenance failures you’re going to need to shorten OCI/FCI to get the “leftovers” out. That’s why I personally think the partial-fluid changes are the smallest shock to the system when talking about long-neglected transmissions.So if you had an engine that was overdue on the oil change, you would change one quart at a time?
There is no complaint about issues, so how do we know that any crud has built up? that we should be worried about loosening up? At 120k all the material may well be held in suspension at this time—this trans likely has a rock catcher, drop the pan to see if there is debris, but I think nothing will be seen.
I’ve watched a few videos of trans teardowns, and outside of carnage, I’m not sure I have seen anything other than dirty fluid? not piles of deposits lurking in corners, waiting to come loose.
Yet on car engines we’ve all seen plenty of sludge, yet no one thinks twice about full oil changes and aggressive cleaners. I get it, different applications with different parts, but I don’t see the need to be careful. Those clutches are wear items and any failure after atf change I suspect is more related to old fluid than new.
The real fix is to do reasonable maintenance on time; roughly 30-50k transmission fluid changes. Then there’s no issues changing the entire fluid volume at once.
