Champion RCJ4 or RCJ6Y
TX
I am currently maintaining my Toro 25cc String Trimmer and noticed a lot of carbon and oil buildup in the spark plug. According to the manual it will take RCJ4 and RCJ6Y. Currently it has an RCJ4 spark plug to it.
If I use RCJ6Y will that eliminate the carbon and oil buildup? In comparison, I have 2 other string trimmers and the spark plugs for both have small amount of carbon and no oil on the spark plug tips (when removed). thanks
EDIT: According to my online research on HEAT RANGE
RCJ4 is COLD
RCJ6Y is slightly HOTTER
@ Escape08, you should be able to visibly tell that porcelain cone (engine cylinder side of the plug) is longer vs the colder plug. Personally I have always run the hottest plug I could in any 2 cycle engine, especially one that gets possible use during the winter time.
Neither :sneaky:
Instead, use either
NGK BPMR8Y or BMR7A
NGK's scale is the opposite: higher number means colder
Unfortunately, the only platinum and iridium options are from Autolite:
Platinum: 264 or 2974
Iridium: XST254 or XST2974
Autolite doesn't use a structured part numbering system like NGK, Denso, Bosch, Champion, or even Torch :poop:
RCJ4 is COLD
2 things:
What oil are you using?
Do you let this trimmer idle alot or run it on less rpm's?
2 things:
SuperTech Syn 2 cycle 40:1
I believe you are on point. I rev less (not full throttle) on this string trimmer to avoid engine noise as a courtesy to my neighbors.
I believe you are on point. I rev less on this string trimmer to avoid engine noise as a courtesy to my neighbors.
Let me help you out here, you can use whatever 2 cycle oil you want, here is where you need 2 make a decision.
The cheaper 2 cycle oils in your trimmer need to be run at almost full throttle once the trimmer is warmed up. The more expensive 2 stroke oils can be allowed to idle 2 a certain extent.
I have been using Amsoil Saber Pro now for almost 30 years at 40 to 1, and I understand about running it at less rpm's or letting it idle. I have a 1 acre property with woods and I am not going to be revving it at full throttle when I am going to take 30 seconds 2 go 2 another tree.
You have 2 other trimmers, what are they?
If I was not using Amsoil Saber Pro, I would be using:
1) Bel Ray HR-1
2) Maxima K2
Someone here will talk about Echo Red Armour, but that is another 2 stroke oil like the 1 you are using that needs to be revved high once the 2 stroke equipment is warmed up.
Then you would want to run a hotter plug than stock.
OPE engines are usually designed to run at full throttle at the speed set by the factory :unsure:
If noise is an issue, consider electric. They are so much quieter, and you'll wish you switched sooner :D
If you can't do electric, Honda makes a 4-stroke OHC engine in that size called the GX25
RCJ4 is COLD
I would use the Champion RCJ6Y. It's hotter and the tip is extended more than your current plug. That should help with the deposits. I would dismiss suggestions using NGK plugs. That likely will not solve anything. If they are that good, why were they not the stock plug?
