A huge issue is low phos. in GF4 oils. ZDDP is the other issue. This is why so many 20 weight oils are loaded with moly to try to help make up for low phos. and ZDDP. When you reduce HTHS,ZDDP something is going to give if not properly modified. I do not think their are many car's useing true roller timeing chains. Their was a time when Toyota OHC I4's used true double roller timeing chains. I have seen them go well past 300,000 miles with no change.
