Which is the forum choice for disc pad replacement: pad ears,hardware clips and caliper piston circumference?
For the caliper pins it will be Sil-Glyde Lubricant, NAPA®.
Absolutely the Pastelub!!!!!!!!! I tried the Ceramlub one time on enclosed pins and it dried out, seizing the pins. I believe the OEM company from Switzerland also labeled the ceramlub for Bendix. Others have reported o.k. results with it. I did not try it on exposed parts.
I can't say enough about the Pastelub. Try a dab of Pastelub under a faucet and water absolutely refuses to mix into it. Besides the exposed metal caliper parts, I use a paper thin coating on rotor hats, hubs, and anywhere else I wish to prevent rust. I also use it on agriculture applications such as exposed gate hinges. It is simply awesome stuff and a tub will last for many years. I imagine it is similar to Molykote 77, but is pao based (I think) vs. the Dow product being silicone.
