I keep a bottle of Zoom Spout Turbine Oil to lubricate fan motors . Even the ones that aren't meant to be lubricated can be oiled . Just dribble enough oil down the shaft into the bushing . It worked for me .
Nope. In a given value one may be shaped like a redbull can, a coke can or oval. As long as the capacitance values and voltage are correct, any can be made to work.Mine looks pretty old and I'd have guessed it's as old as the unit, but it definitely appears that the strap and one of the screws has been touched. It's a Packard 35/5, 440v capacitor and is much shorter than the ones I've seen. Do the modern ones all just use a common 'shell' for cost reasons ?
I do prefer Ace Hardware, even if more $, since their location is much more convenient, but theirs are made in China.... From the looks of it, Lowes does NOT stock capacitors in stores. Anyone seen them there ?
Don't forget the one in your furnace for the blower motor. They go bad too and will leave you with a hot house. . Usually around 7.5 mfd. but check first before buying.I keep a spare on hand
If you have a Costco close by Try them for furnace filters. I bought a 4 pack of the good 3M filters for almost what two cost at WalmartDriving home from a week out of state yesterday (Saturday), Wife stated one of two central air units is not working, one thermostat is reading over 80 degrees.
Arrived home 1am this Sunday morning. Got to work on the issue after waking up. Watched two youtube videos on capacitor diagnostic and replacement. Went and checked the unit out, and off to Home Depot for a replacement capacitor.
Everything was extremely easy. Less than an hour from start to finish, including a run to Home Depot. Only issue was old capacitor didn't have the terminals labeled. Easy solution- on the capacitor, one terminal has two lead, one terminal has three leads, one terminal has four leads. So used the lead numbers as the key. If I didn't have that to go with, I would have pulled one terminal off to isolate the fan, then I would have reduced the amount of error risk.
Numerous stories point that a service call to replace the capacitor can easily run $300-$500. I didn't know how long the wait is for a technician. The capacitor before tax was $18. (I don't know why the label price was $24).
Finally, I want to thank the BITOGER that started a thread that Home Dept sells capacitors. I did a search but couldn't find his thread. His thread triggered me to go to HD for the capacitor. I would not have thought HD sold them. BITOG has hundreds of active and positive contributors. And about a dozen trolls/ baiters. Glad the HD capacitor thread starter posted, rather than not post because of the trolls/ baiters. The capacitor thread starter saved me hundreds, and who knows how long for a technician. And maybe the technician might not be honorable and try to sell a replacement unit in the thousands. Had the trolls/ baiters discouraged the HD capacitor thread starter from posting the thread, my morning may have gone very different- thanks HD capacitor thread starter!
Supplementally, purchased an air filter while at Home Depot. HD quit selling 3M filters, the sell HDX filters that are packaged to look like 3M filters. These HDX filters are very pricey; the filter was just .50 less than the capacitor. I will be buying home air filters from Wal Mart from now own.
Lowe's project source Merv 8 filters been reliable and priced good. $13.97 for a 3 PK.If you have a Costco close by Try them for furnace filters. I bought a 4 pack of the good 3M filters for almost what two cost at Walmart
Good point to mention even a low voltage short such as the communication wire from indoor unit to the contactor could blow a transformer. seen this happen plenty of times landscapers are notorious for chopping into the wiring with the weedeater. could also save the expense of control boards and the headache of finding replacement boards for older units.Anyway, as an FYI, older Rheem units use the 24 VAC transformer on the control board as a fuse for the compressor's contactor. So if the contactor goes bad and draws more than about 1 amp, it blow's the secondary side of the transformer. So if the blower motor on the HVAC system suddenly stops while in AC mode, check both the contactor on the AC outside unit and the 24 VAC transformer on the HVAC system's control board. Replacement Rheem 24 VAC transformers fortunately now come with an inline fuse to prevent the need to replace the transformer.
I believe that's what HVAC Guy on YT uses, along with a foaming adapter.
the secondary side can handle 1.66A on a healthy 40va transformer, a 2A fuse is fine and either will work in a dead short situation. two drawbacks I could point out with the 2A fuse isI found that the compressor contactor's primary side resistance does not have to change much for it (the contactor) to pull more current than the protective fuse can handle. In my case the primary side resistance has always decreased relative to the Primary side's resistance reading I get for a brand new Rheem contactor
As an aside, I am using 2 amp ATC fuses.
