The answer depends on the height of the tower above ground, obstructions, line of sight, and terrain. The range could vary from just a mile to several dozen miles without any obstructions. Out on the open water, my range is limited to a few miles. No idea why it's not more. If you need a greater range get a weBoost which will increase the range by maybe up to 50%.Assuming no obstructions, what is the range of a cellphone transmitter? Are there different designs that transmit different distances?
Thanks!The answer depends on the height of the tower above ground, obstructions, line of sight, and terrain. The range could vary from just a mile to several dozen miles. If you need a greater range get a weBoost which will increase the range by maybe up to 50%.
They don't put out as much power, because there is no need to. More power = more interference for your frequency bands that are in the area.Out on the open water, my range is limited to a few miles.
In perfect, optimal conditions and terrain a 4G signal can go 30 miles before it is completely useless. Normally it's a lot less
4G or 5G modulation doesn't have anything to do with useable distance, frequency does.A 5G signal is closer to a mile.
The earth curves about 8 inches per mile. A 3-story building is about 40 feet tall. So 60 miles in theory? I don't think so. Maybe 5 miles.Thanks!
Here's a hypothetical: Transmitter is atop a 3-4 story building very close to the waters edge, no obstructions as there's only an open ocean to contend with, and the phone, a good quality Android or iPhone, is on a boat. At what approximate distance could one get a good signal?
I would expect some change but presuming a flat desert landscape not a significant difference. I could be completely wrong. Rest assured COMMS fails when you rely on it.Would being in a similar situation but where the signal is sent over land, such as in a desert environment, change the range versus going out over water?
Can a cellphone 30 miles away have enough power / range ping this tower?In perfect, optimal conditions and terrain a 4G signal can go 30 miles before it is completely useless.
Don't laugh but I know a few locations along the coastline with very spotty or no cell service where I can get a connection simply by getting up 10 feet higher.Can a cellphone 30 miles away have enough power / range ping this tower?
Now it's our turn. Why did you ask this question? Are you trying to make a call to your caviar-smuggling friend who's trying to arrange a cloak-and-dagger dropoff at a secret cove at midnight?Thanks for all the information. You've shown once again why BITOG is often a better option than Google to ask a question. More info than I'd have thought to ask about.![]()
I've been invited to go out on a fishing boat and I've had some bad experiences on the water. In addition, I'm not very comfortable in and on the water, although I do like the experience of being on various types of boats. Now that I have a cellphone, and know its capabilities, my comfort level may be raised a notch. I know it's not a panacea for mishaps and issues on the water, but it does raise my comfort level somewhat.Now it's our turn. Why did you ask this question? Are you trying to make a call to your caviar-smuggling friend who's trying to arrange a cloak-and-dagger dropoff at a secret cove at midnight?![]()
I hope you have a bigger boat. Don't forget to put some Sharktec Time-Release Shark Repellent in your lifevest. And if you do go "swimming" and a shark gets close, punch it on the nose, claw into its gills, and gouge his freaking eyes out. And for Saint Elmo's sake, stay away from the maw.I've been invited to go out on a fishing boat and I've had some bad experiences on the water. In addition, I'm not very comfortable in and on the water, although I do like the experience of being on various types of boats. Now that I have a cellphone, and know its capabilities, my comfort level may be raised a notch. I know it's not a panacea for mishaps and issues on the water, but it does raise my comfort level somewhat.
Sending a signal over open land is easier than open water. The water can act as a reflector and skew the path of the signal.Would being in a similar situation but where the signal is sent over land, such as in a desert environment, change the range versus going out over water?
