That's right .... Its suppose to go to a different Tower when you do thatLike turn it off and back on? If so we do that most every night.
assuming there is another tower availableThat's right .... Its suppose to go to a different Tower when you do that
I was on Mint owned by T Mobile and it would just not work even tho their map showed I have 5G. I went to Cricket owned by AT&T from the same tower have 5G.we are on metro and they use T mobils service
They may be able to manually push you to a different tower, but that's a temporary change that will expire after a short time period.One thing you might try is calling them and asking if they can register you to a different tower. They did that twice for me and it worked for a short time.
So that answers the question. It only worked for a short time. Also I'm thinking these towers go down more often than we realize.They may be able to manually push you to a different tower, but that's a temporary change that will expire after a short time period.
Are there any other booster systems that work that are cheaper? Also in the last couple of days AT&T had major outages all over the country. It affected calls to other carriers and vice versa.![]()
CEL-FI GO X G32
The Cel-Fi GO X is an in-building signal booster system that utilizes Nextivity’s Cel-Fi Smart Signal Booster technology to significantly boost voice and data coverage.www.waveform.com
I have this, and is solves the issue 100%. Without it, sometimes 1 bar 4g, with it, 4-5 bar 5g.
@Chris142
Doubtful. All installation, radios, equipment, etc are carrier grade and are very reliable.So that answers the question. It only worked for a short time. Also I'm thinking these towers go down more often than we realize.
If the cell network is tuning into live video broadcast it slows down things or ends up making you deprioritized dependent on your specific plan.I dont see how that would effect my cell phone though
This is HIGHLY carrier dependent.Overall you will experience better signal and longer range with LTE Vs 5g cell coverage especially in more rural areas and outside of cities.
In our coastal area I previously posted my iPhone 13 and T-Mobile service would suffer in some areas by trying to make use of a weak 5g signal instead of using the LTE signal. Sometimes inside of stores it got unusable and traveling in rural areas would at times too. SO I turned off 5g on my cell and selected LTE only. I think it improved but shortly after I dropped T-Mobile anyway so did not have a long term test.
I can confirm (and someone else in here backed me up with the same experience or similar) My new service with Verizon through US Mobile works better in rural areas when going inside of stores. Need more time to confirm but Im pretty sure there is no doubt in my mind being able to use my phone in stores that I couldnt before.
The new service shows a weak LTE signal with Verizon that works vs T-Moible at the time trying to use 5g and would not work inside a few stores. They all use the same towers in most places around here.
Anyway, if you are one to have issues with your phone connecting at times (in less populated areas), you may want to try setting your phone to LTE only and see if it improves. Nothing to lose trying it if your in a fringe area your phone wont "fight" itself trying to use a weak 5g signal and use the reliable LTE instead. (my personal opinion/ limited experience trying it)
"Rolling out new networks take time. The fact 5G isn’t quite as good at performing over long distances also means LTE will hold out a bit longer until innovations in 5G bring better parity here."
LTE vs 5G: What are the differences and do you need 5G?
Curious about the difference between LTE and 5G? In this LTE vs 5G comparison we take a closer look at how the tech differs.www.androidauthority.com
Most problems are either line of sight or they cannot build new towers because of NIMBY or other politics (it cause cancer...... or headache ..... or ringing in my head ..... or looks ugly, etc). Obviously you can't reason with people like that and you just have to let them deal with bad receptions.Doubtful. All installation, radios, equipment, etc are carrier grade and are very reliable.
Not that I know of. This system is not a normal booster, in the sense that the typical cheap "booster" just brings the signal that is outside, into a building....those are much cheaper.Are there any other booster systems that work that are cheaper? Also in the last couple of days AT&T had major outages all over the country. It affected calls to other carriers and vice versa.
You live in Silicon Valley, a developed area. We live in Coastal Communities of NC and SC in the most rapidly developing area of the USA. (just explaining)This is HIGHLY carrier dependent.
Some carriers bid for better spectrums and therefore can penetrate barriers like buildings better. TMo used to have a lot of problem for indoor receptions until they get some AWS band (that was in the late 2000s early 2010s), and now the former 700MHz TV FM bands are refarmed into cellular it really helps with building penetrations.
What each carrier use for 5G vs LTE are really dependents and will change over time. Most carriers can't LOCK you into one particular tower and if they do, it may cause you problem elsewhere when you move out of your tower's coverage. Just switch carriers (or get a newer phone with newer bands supported) if you have bad reception is what I would recommend. This is why I would always pick a newer iPhone SE over an older top of the line iPhone Pro: the new one has more recent radio support.
