JHZR2
Staff member
Then I suspect you are deprioritized as compared to real t mobile users.we are on metro and they use T mobils service
It is the same as going from dial up to DSL. I remember we used to have data cap per month like 1GB for $70 but now you can get $15/mo with 1GB or so, and nothing else has changed.Feels like 5G is a solution for a non-existent problem. Maybe a money saver long term if your thoughts are correct.
My DSL has gotten really expensive. I called to find out why and they told me I have the premium 384k up package, and nobody can even order it anymore. All the more reason to keep it.Don't you get electricity from a power line? Don't phone cables use the same power poles?
That is a important piece of the puzzle, and 100% true. They can and do throttle non specific customers.Then I suspect you are deprioritized as compared to real t mobile users.
No, 4G vs 5G modulation has nothing to do with range. The frequencies used in either 4G or 5G are what affects the range. If you put a 4G and a 5G radio side by side using adjacent frequencies and bandwidth, the range would be the same and the 5G throughput and scale would be much better. If you had 700MHz frequency assigned to the 5G radio and 5GHz assigned to the 4G radio, the 4G radio would have much shorter range and higher throughput.4G has more range than 5G but 5G has better bandwidth.
Like what? I have not heard anything latelyI suspect it was limited due to a major announcement Th afternoon.
My plan is unlimited and my carrier "may slow my data rate during times of congestion". I've never once seen my carrier slow my data rate nor have many other people I know that have the same plan and carrier. Believe me, we have tried.So how many have truly unlimited data plans? I've found faster service isn't any good if you hit their high speed data cap and then they slow you down to 3G service.
Consumer Cell use to but have now go n back to a 50Gb limit then the slow down. Best I could find last time I looked was Verizon and at about $200 a month for 100Gb.
So whose your carrier ? It's usually buried very deep. It's pretty easy to tell when downloading and I have an old data rate app on the PCs.My plan is unlimited and my carrier "may slow my data rate during times of congestion". I've never once seen my carrier slow my data rate nor have many other people I know that have the same plan and carrier. Believe me, we have tried.
I dont see how that would effect my cell phone thoughA public figure was convicted of 34 felonies.
Like turn it off and back on? If so we do that most every night.If you are getting a poor signal ..... reboot your phone
Agree, 3g is useless now.So how many have truly unlimited data plans? I've found faster service isn't any good if you hit their high speed data cap and then they slow you down to 3G service.
I have an unfair advantage, I work for my carrier and have a ton of insights into the network that most don't.So whose your carrier ? It's usually buried very deep. It's pretty easy to tell when downloading and I have an old data rate app on the PCs.
Even Verizon had a max high-speed data limit where they slowed me down. I should say this is for 4G hotspot.
