Ceiling fan will not reverse direction
Then I noticed that there was a large remote control module plugged into a different plastic plug.
Now for the “ Rest of the Story”. The two fans with the Casablanca wall controllers were actually remote control units. The center button was for reversing the direction. Duh, I should be dipped in hot 5w30. :rolleyes:
So it wasn’t totally a waste of time, here are a few more shot of some of the components inside the fan body. There was also a connector for an optional light that could have been added and controlled by the remote control. Also, the remote control module was plug and play. The chain was for manually controlling a light, AFAIK.
I have a large Hunter fan with wide blades that I installed a number of years ago. It had the lights as well. Installation was straightforward and all the wires were color matched to the appropriate plug module. Easy as pie or so I thought.
I got it all wired up and closed up then tested it. Everything worked except the lights. Took it apart and everything matched the instruction manual. Still no lights. After several rounds of playing with different routing I came up empty. The lights are just decorative now. I never figured it out. The fan works well.
Does it have the chain gizmo?
