Originally Posted By: dlayman
Assuming no irregular tread wear, what causes some tires to get noisier with age?........
I'm going to reject your premise. I think tires getting noisier due to age IS caused by irregular wear and irregular wear alone. The difference between a vehicle that is out of alignment and one that is "In Spec" is a matter of degree. It just takes longer for the irregular wear to form with a vehicle that is only slightly off target.
And even though you may not be able to perceive irregular wear, that doesn't mean it isn't there. The point where the irregular wear develops enough noise and/or vibration (the difference between the 2 is frequency) to be perceived is sooner than the point where you can pick it up by rubbing your hand over the surface of the tread, and even further down the road, being able to see it.
Originally Posted By: friendly_jacek
here is my understanding:
1. aggressive block pattern (should be always noisy)
2. abnormal wear from bad alignment or lack of rotations (gradually gets worse)
3. tread separation (sudden change)
4. "slipped"/broken/defective belts (still fuzzy about this one)
1. Agree, but I should warn folks that even completely smooth tires generate noise, because the road surface has macrotexture.
2. Sort of agree, but lack of rotation is just allowing any slight misalignment more time to generate irregular wear, so I see this as a single cause - not two!
3. Completely disagree. I think separations in tires generates a vibration not noise (But I will concede that noise and vibration are different frequencies and perhaps a separation might also generate a noise, but that is not my experience.)
4. I need to break this into 3 parts:
a) I don't think there are such things as slipped belts. I think people cite that as a cause for either a separation (not true) or irregular wear (also not true). Belts don't slip. They are 100% encased in rubber and the rubber doesn't allow the belt to move. (OK, there is a thing called compression set that is sort of rubber flow, but that's a different thing altogether.)
b) I know that sometimes people will find the wires broken in the belts - and I think that is a form of separation, and the result is sometimes this. But not every separation contains a broken belt and the cause of a separation is never the belt breaking.
c) Defective belt. This is more difficult in that I think most separations are faulty designs (the materials used in the belt package and way the belts are configured) and not what we normally this of as a "defect (something there that is not supposed to be there or something not there that is supposed to be there.)
But having said all that, I don't think separations generate noise as much as they generate vibrations (again with the proviso that noise and vibration are just different frequencies)
And lastly, I think irregular tire wear noise and bad bearing noises are easily confused. I think that if a noise shows up suddenly, it's more likely a bearing, and not a tire.
So I think the OP should be looking at the bearings.
Oh and one last thought: Dismounting a tire does not help in diagnosing a separation. Bulges are more likely to show up when the tire is inflated. Rubbing your hand over the tread surface (with gloves, of course!) is a good way to detect a small bulge.
