Quote:
Mile 18,000 -- John Richardson, September 29, 2003.
Oil/Vehicle miles: 18,021 / 27,960
Oil added after sample: drained oil!
Well, it's done. At long last, we drained the oil. Considering that we've gone two and a half times longer than we thought we'd go, we're pretty impressed by Mobil 1's longevity. Our Dexsil TBN test resulted in a 6.0, comparing favorably to Blackstone's 6.5. But speaking of high TBNs, what happened to this oil? If it had posted these numbers at the last interval, we wouldn't have dumped it. This oil could have kept going based on the numbers we have now, but they sure weren't looking this good a thousand miles ago. Viscosity was dropping, TBN rising, and what's going on with the insolubles? Meanwhile, despite all these paper improvements, the engine still had higher oil pressure and wasn't running as smoothly as normal, so clearly not all was perfect with the oil.
"the engine still had higher oil pressure and wasn't running as smoothly as normal"
Quote:
Mile 14,000 -- , December 2, 2004.
Oil/Vehicle miles: 13,994 / 44,970
Oil added after sample: none
This is it. Amsoil is done! The oil exceeded a year in service, with 14,000 miles on the ticker, and no filter change! Well, if the year hadn't ended, we would have had to change the filter now -- it finally reached our insolubles cap, 2,000 miles after Mobil 1. The main thing that stands out on this, our final Amsoil sample, is the ridiculous viscosity. This 5W30 oil has now thickened out to a 15W40 -- argue whether it matters if you like, but we believe engine builders spec an oil for a reason, and this oil is far, far thicker now than intended for the LS1. Switching to our flush Mobil 1 netted a nearly instant 10% improvement in fuel economy, and the engine runs a heckuva lot smoother too. To Amsoil's credit, wear metals remain in check, but we will soon see whether that was really thanks to the oil or just to engine break-in. We'll start posting detailed analysis in the coming weeks.
"and the engine runs a heckuva lot smoother too."
