Originally Posted By: m37charlie
Even the CJ4 limit is 1200ppm P, which corresponds to ~1300 ppm Zn. Enough for virtually any diesel with flat tappets. Diesels, by virtue of lower rpm limits, do not come with high pressure valve springs. The whole flat tappet "thing" is largely related to high valve spring pressures on high rpm high performance (gasoline) engines.
Charlie
Yeah, CJ oils were lower in zddp for a year or two, but lately there has been an noticeable trend back to almost CI4+ levels in most oils.
