Well, 15w-40 is a common diesel oil viscosity so that would be my guess why they label it that way. I don't believe I've seen this version in the USA so I don't know anything about it.
Yeah but the data sheet claims it is specifically optimised for diesel
Castrol MAGNATEC Diesel contains dedicated diesel technology and breakthrough DUALOCK molecules that cling to critical engine parts and lock together to:
Form a powerful force field of protection
Dramatically reduce both warm-up2 and stop-start3 wear by 50%
Deliver unique patented protection designed specifically for modern driving
Help maintain engine efficiency and responsiveness in common rail diesel engines Deliver excellent soot handling performance
Non-stop protection from every start.
1 Global average from 50 cities, Castrol MAGNATEC STOP-START Index 2014 2 Tested versus the Sequence IVA API SN wear limit.
3 Tested versus the CEC OM646LA ACEA wear limits.
Application
Castrol MAGNATEC Diesel 15W-40 is suitable for use in automotive diesel and gasoline engines where the manufacturer recommends an ACEA A3/B3, A3/B4, API SN 15W-40 lubricant.
