I'm going to be changing the ATF in my 92 Accord Lx A/T w/ around 210000 miles on her. I changed the fluid about 2 years ago and just drained what was in the pan (around 2.4L) and changed it with some Maxlife DEX/Merc Synthetic Blend from Walmart, the manual calls for a Dexron II fluid. The previous owners were really cheap so who knows what the other 2/3 of fluid is running through the transmission, probably the cheapest no-name stuff they could buy. I was planning on just buying another 5L jug of Maxlife from walmart again its only 20$, but i also saw the Castrol Multi Import ATF which caught my eye and checked that out as well. I started looking at the specs for both oils and the ATF that I normally would have ignored is starting to not look that bad and maybe better than Maxlife.
CASTROL
Viscosity at 40°C, cSt - 36.6
Viscosity at 100°C, cSt - 8
Viscosity Index - - 200
Brookfield Viscosity at -40 C, cP - 10,500
Pour Point, ºC (ºF) - -48 (-54)
Flash Point, °C (°F) - 208 (406)
Specific Gravity, 60°F - 0.862
Meets or exceeds JASO-1A requirements
Maxlife
Viscosity at 40°C, cSt - 28.18
Viscosity at 100°C, cSt - 6.11
Viscosity Index - - 173
Brookfield Viscosity at -40 C, cP - 8400
Pour Point, ºC - -51
Flash Point, °C - 202
Specific Gravity, 60°F - 0.843
JASO-1A requirements???
The other differences I can spot are Castrol is Conventional, and probably the Maxlife has more wear additives and is a synthetic. Tough choice both look really good.
CASTROL
Maxlife
