I was recently comparing the spec sheet of Castrol Import Multi-Vehicle ATF against the specs of the newly reformulated Mobil 1 ATF and came across what I found to be surprising. Both products are recommended by their manufacturers for use in exactly the same applications (both are recommended for virtually any automatic transmission ever made with the exception of CVT's and those calling for Ford Type F or Dexron VI ATF) yet the Castrol ATF has significantly better flash and pour points! If I were to make a judgment based simply on the spec sheets it would appear that the Castrol Import ATF is the superior the two.
This seems at odds with the current pricing, as the Castrol Import ATF is sold at $6 Canadian a litre (based on buying the 3.78 litre jug for $22), while the Mobil 1 ATF sells for $9+ per litre.
Castrol Import Multi-Vehicle ATF:
Flash Point= min 208 Celsius
Pour Point= -48 Celsius
Mobil 1 ATF:
Flash Point= 200 Celsius
Pour Point= -41 Celsius
http://www.mobil.com/USA-English/Lubes/PDS/NAUSENPVLMOMobil_1_Synthetic_ATF.asp
http://www.castrol.com/liveassets/bp_int...ds_ImportMV.pdf
Why is the Mobil 1 ATF priced at 50% more than the competition if it isn't even matching the specs of its lower priced (and non-synthetic) competition?
I thought one of the main selling points of synthetic ATF was its superior performance in extreme cold and extreme heat?
Comments?
Mobil 1 ATF:
Comments?
