I have a 2.0l ecoboost in my Fusion. I've had a couple of different oils in it so far, Motorcraft FS 5w30 and Castrol Magnatec 5w30 FS. Did a used oil analysis with the Magnatec at 6000 and it was pretty good (low fuel, sheered to 20) but probably wouldn't push it much further than that. I'd like to just pick one for a while so I can stock up. I would really like to hit a 7000 OCI (no real reason) but worried that the engine may require extended life oil for this particular engine. When I was looking at prices I saw Castrol Edge a few bucks more so then I thought would it be worth it to bump up to Edge? I know the Magnatec is their value FS (which works well) but for an extra 5 bucks per oil change I could go up to the Edge. I'm not married to Castrol either but from what I've read on here, it plays nicely with the Ecobost engines.
I live in the city of Chicago, so a lot of quick starts, stop/go, varying temps all over the board, and a decent amount of long trips with fully loaded car. Would go to Edge be worth it? Would it help push to 7k OCI? I appreciate your thoughts. Thanks
