Castrol Edge 5W-40
istanbul, turkey
First post coming up, here we go.
Proud owner of a 2006 S2000 (EU version, 2.0L, 8900rpm).
Honda Manual states 10,000 km for the first oil change.
Honda extreme condition schedule states 6,250 km for the first oil change.
I'm in bumper-to-bumper traffic almost every day somewhat between 15 minutes to an hour sometimes more. I'm also over 100mph daily for extended periods of time, am frequently above 6000 rpm constantly on the highway, etc, etc.
I decided to get my first oil change at ~7,250, scheduled maintainence for tomorrow. Honda manual says: " 'ACEA A3/B3', API Service SL or higher grade, 5W-40 or 10w30."
I got my hands on a 5qt/4L bottle of Castrol Edge 5W-40.
On the back it says:
API SL/CF, ACEA A3/B3/B4.
My question is... isn't "CF" for diesel engines? I know oils can meet both diesel and gasoline engine standards, but do I want such an oil? Is there any reason not to prefer such an oil?
The Castrol website is even more confusing.
The UK site says the 5W-40 Edge is for turbo diesel engines.
The TR site doesn't mention anything about diesel engines, but, on the Turkish label on the bottle it does mention that it will perform well in turbo engines (does NOT say "diesel").
My thinking is this--as long as it meets the Honda requirements (ACEA, A3/B3, API, SL, 5W-40), I'm good to go, right?
...right?
Castrol UK site "Edge Turbo Diesel 5W-40": http://www.castrol.com/castrol/productdetailmin.do?categoryId=9004873&contentId=7009125
Castrol TR site "Edge 5W-40": http://www.castrol.com/castrol/productdetailmin.do?categoryId=9010163&contentId=7019161
Now, I know you don't know how to read Turkish, but, I'm sure you can see for yourself that you don't need to know Turkish to see the difference between "Turbo Diesel 5W-40" and just plain "Edge 5W-40".
Someone help me sleep better tonight
You got it. If it says API SL and ACEA A3/B3, no worries. Basically all good oils meet API CF which is an older diesel spec. Even ACEA B3 is a light diesel spec. Use the 5W-40 Edge; it looks like a good oil. But it's humorous how your owners manual's recommendation is so different (thicker) than the US recommendation. That's been known for a while on this site though. By the way, it sounds like you drive your S2000 like it should be!
Awesome. I owe you one
Thanks! I try
By the way, I test drove the older S2000 that has the 2.0L engine and it was insane when V-Tech kicked in. It felt like I was in a motorcycle. Is your newer, larger engine really impressive too?
