Originally Posted By: CATERHAM
I suspect Edge 0W-40 will be similar and IIRC PU 5W-40 and 0W-40 are nominally around 11.5% as well.
So M1 0W-40 has 20 point higher VI and a NOACK under 9%.
To consider buying either BC, GC or PU it would have to be pretty cheap over the already inexpensive and readily available M1.
I am going to have to agree with you. When price,availability and certifications are all taken into account M1 0w-40 is very tough to beat if an engine requires those certifications.
There are better oils out there in my opinion however once the whole package is considered Overkill pretty much nailed it.
"Nectar of the Gods"
PU is a better oil in my opinion however since availability is sporadic,if even attainable. Or has to be ordered online. If I'm going to order oil Amsoil is pretty much the top of the food chain in that department so if I've gotta order oil its going to be Amsoil.
Tough to find it on rollback though,so while you guys talk shop about these top notch products I'm going to count my change so I can get a jug of PYB.
