Castrol Edge 0W-40 SP VOA
Attached is the VOA for the Castrol Edge 0W-40 API SP formula. Enjoy!
It's probably not new but they reverted to a non titanium add pack?
I'll have to go examine my stock to see what has Titanium and what hasn't...I have the bad habit of grabbing a jug every time I'm at Walmart and it's on special.
978 on the Zinc, why not 1000 on the Zinc, my fault this is SP!
Could just be measuring deviation. You can test the exact same sample a dozen times and all the numbers will never match. Nonetheless even if it really was 978 zn and 886 phos that's still fine. It does have 74 of moly. I don't know if it's trinuclear but it's 2024 so it probably is instead of the older dinuclear which needs to be in much higher quantities to be productive whereas with trinuclear the benefits drop off after 75.
I know there are some doubters here but the Magnesium shows they are trying to accommodate lspi. Thanks for testing.
Yeah, API SP + LL01 is the main reason why I'm trying this oil. I know LSPI is rare in B46TU1, but I just want to be on the safer side :)
So many forumites only relate Magnesium to a anti-lspi engine fight.
Looking for members that bet heavily on it's carbon-fighting attributes as a detergent additive.
A BITOG Recruiters Meeting at 7:00PM tomorrow. Moly Synergists invited also.
I know this has been beaten to death, but is there any significant difference with M1 0W40 now? Here the Castrol is always a few $ more expensive, any reason to pick one over the other?
Castrol Edge 0w-40 A3/B4 seems to be more in common with Mobil's 0w-40 FS Euro.
Here's what I see:
  • Mobil 1 shows a HTHS (3.8) while Castrol does not.
  • Mobil 1 is higher starting visc. 13.8 vs 13.3
  • Mobil 1 has higher VI
  • Mobil 1 has lower pour point
  • Mobil 1 has higher flash point
I think you know what I'd choose but if the price was right the Castrol is still a good choice. Throw in a Mobil rebate it's an easy decision. Here are their respective PDS's.
https://msdspds.castrol.com/bpglis/...C46EDB080258B1700300C40/$File/wepp-d5427r.pdf
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-fs-0w-40
Here's what I see:
Where do you see the HTHS? I only see it for ESP X3/X4 0W-40.
