ekpolk:
To your point, one could indeed just as easily say "why bother" as "why worry": They're probably both valid. I can't speak to this particular application, but can only point to my 99 Saturn, a 95 Civic, a 95 Integra, two Escorts (one 91 and the other 93), a 90-something Tempo, and a 91 Tercel: all well in excess of 150,000 miles, all running Xw-40 or Xw-50 weights year-round in said Chicago weather.
For my part, the switch to Castrol 5w-50 was precipitated by leaking seals that weren't fixed by several Auto-RX cycles, and a consumption rate of 2 quarts/3000 miles. The car was steadily ramped over its life from 5w-30 to 5w-40 and finally 5w-50. Lowest rates of consumption and minimal leaking with the Syntec. Is the oil thinning out? Maybe. I doubt it. I've never pulled an analysis, but all the UOAs I've seen of Syntec 5w-50 would lead me to believe it's holding its viscosity just fine.
As to your comment about manufacturers' recommendations, yes, I am suggesting they're worthless. Well, one caveat: in the U.S. at least, I don't believe they're worth the paper they're printed on. Will the suggested weights ruin an engine? No, I don't believe running a thin oil will do any more or less harm in a modern engine than running a thick oil. But do those recommendations really have anything to do with the engineering specs of the engine? I don't believe it. Has more to do with CAFE and selling a low sticker MPG than anything else. As I've said multiple times here before, one need only question why identical motors in identical cars suddenly go from requiring 50 and even 60 weight oils in European countries of similar climate to 20 or 30 weight mid-way across the ocean. Are we starting to see the change in European and Asian cars? Yes, but again it's a case of "what they can get away with," not "what's best for the car." The same great minds are giving us cars with electric water pumps, no dipsticks or temperature gauges, 100,000-mile spark plugs, and pressurized braking systems that brake no better than standard but require three years of doctoral study and a willingness to sacrifice all the fingers on one hand in order to self-service.
