With regard to the flat tappet engines that ruined cams during break in, did it use up all the zinc or was it simply a defect or assembly issue? Don't know many guys that had it happened called it an error on their part of putting it together.
No verdict. LOLso after all this above from you experts, What's the verdict on the Castrol 4T 10w40? Canadian Tire has it $7.99 a liter.
I saw Castrol GTX 10w40 at the Canadian Tire store, is that the Castrol Full synthetic?I use the Castrol ActEvo part synthetic in my motorcycles. They run and shift great. No problems.
The Castrol Full synthetic is supposed to be even better than the ActEvo. Go ahead and use it.
There is a conventional oil and then there is a 4T full synthetic.just looked and the store web site says the Castrol GTX 10w40 is Conventional oil
I've used the Valvoline 10W-40 conventional 4-stroke motorcycle oil in a couple different bikes and it works well. Not sure it's available in Canada, but Walmart sells it here in the US.Canadian Tire store doesn't have the Castrol Power 1 but they do sell the Castrol ActEvo part synthetic 10w40, I do want to have a 10w40 for my '05 Kawasaki Vulcan 800 water cooled wet sump motorcycle and searching for which 10w40 to get.
The Power 1 has a much lower Noack compared to the ActEvo and Go! formulas.Castrol Power 1 is the full synthetic 4T oil
Castrol ActEvo is the part synthetic 4T oil
Castrol GO! is the conventional 4T oil
Motorcycle oils usually have the 4T designation on the bottle. Also, somewhere in the specs listed, will have JASO MA or MA2 listed on the bottle for wet clutch compatibility.
Link to Castrol showing their motorcycle oils (in the United States). I just typed "motorcycle oil" in the search bar on their website.
https://www.castrol.com/en_us/unite...rcycle-engine-oils/motorcycle-oil-brands.html
Yes, some people run car, truck or diesel oil in their motorcycles. I do not, so I don't have an opinion on which one of those is best.
You said in another post you ordered a case of Petro Canada Duron 10w40... did you change your mind again?Canadian Tire store doesn't have the Castrol Power 1 but they do sell the Castrol ActEvo part synthetic 10w40, I do want to have a 10w40 for my '05 Kawasaki Vulcan 800 water cooled wet sump motorcycle and searching for which 10w40 to get.
