Carwell spray gun
Near the beach in Delaware
I just received a Carwell spray gun. The nozzle sections look like they lack precise manufacturing. More like they took brass tubing and crimped it in a vise half way closed to form the nozzle. I have not tried it. Yes its undercoating not auto paint.
Yes, it is not a precision item. I have two wands, one with four holes drilled in to provide spray in all directions into an area that you cannot see, and then one that is bent at an angle and just provides atomization of the spray in one direction in a fan of sorts.
I mainly use the second one. Works well. You may need to play with the pressure, and if using T40, make sure it is in the house and warm before trying to spray. If it gets too cold, it is tough to spray.
