Carquest Premium 85372 C&P
BrendanC
$100 site donor 2024
Houston, TX
2008 E350 5.4L V8 82k miles
in service 6k
out/off: 5 quarts Valvoline EP HM 5w-30 and 1 quart HPL EC30 with Carquest Premium 85372
in/on: 6 quarts HPL PCEO 5w-40 with carquest premium 85372
filter looks great as always.
Great PG filter, as always. I’ll have some CQ Premiums here to cut open in a couple thousand miles as well. Thanks!
Looks good, thank you! Are the Pentius XL filters essentially the same filter? Thinking about these or the PG's for all of vehicles.
My new (pre-owned) vehicle uses a cartridge; no C&P drama - just Yank and Gawk.
I am waiting for the day when a poster can't bend a Si rubber ADBV with their thumb.
Thanks @BrendanC for the c&p.
Probably the best filter out there now. Reminds me of the OG Fram Ultra!
Very good oil filter - just wished the outer gasket was a little thicker / beefed up to seal better as I had to tighten mine down a bit more than my previous Fram Ultras to prevent oil leaks in the drive way .
If you are looking for OEM media and flow specs in a stronger built USA made and owned filter check out www.baldwinfilters.com They do a lot of Heavy duty and industrial worldwide, but also do automotive. If you buy them from Amazon or the like you will pay about twice as much as if you look up and buy from your local Baldwin parts jobber. They are not in the micron rating race, they match the OEM specs, on purpose.
