- Joined
- Jan 26, 2021
- Messages
- 20
Long time listener, first time caller. I'm usually a snob about filters and oil, like many of us here. But in the interest of convenience, I decided to use the Carquest filter that I got from Advanced with the 5 gallon oil jug combo. Now, I need 8.5-9qts in my truck, so I need to buy two gallons. Two gallons = two filters. I also had a filter leftover from my last oil purchase (I used a Mahle filter I had bought previously on for that change), so last night I had my choice of three Carquest cartridge filters, all the same PN.
One didn't fit, the snout was a few mm too thick to fit inside the housing on the motor side. It looks like the taper wasn't cut into it.
Another was missing one of the two o-rings on the snout of the filter.
The third? Just right.
I already bought a Mahle filter to either have on the shelf or replace the Carquest filter as soon as it comes in, but it will probably be fine? I'll more than likely just run a short OCI with this change, and go back to buying my oils and filter online (my local Walmarts are extremely hit or miss and not worth the trip). I also realized my last two changes with with regular pennzoil platinum, and not the ultra platinum, I wasn't aware they changed the branding and colors up on the jugs.
Just wanted to post my experience.
