Carquest and MicroGuard oil filters
I know that the CarQuest and MicroGuard oil filters are considered two of the best oil filters on this forum. I understand that both are rated for 99% efficiency at 20 microns. First, is there any difference between the two filters or are they exactly the same other than the name printed on them (i.e are they constructed exactly the same with the exact same internals)? Second, I was wondering if anyone has any data on the flow rate of these two filters? The 99% efficiency sounds great but if they don't flow as good as a less effecient oil filter, you could be starving your engine of oil periodically. In other words, you can make a filter that is 99% effecient at 5 microns, but the flow rate would probably be way too slow for a engine to survive. I'm just wondering if they flow comparable to other less efficient oil filters or does the 20 micron rating cause a slow down in oil flow? Third, are there any other brands of oil filters that offer the same filtration efficiency to the CarQuest and MicroGuard filters?
Carquest Premium is 99.5% @ 20 microns but the Microguard is nowhere close in efficiency. The best basic oil filter is probably the Purolator Red can at 96.5 @ 20 microns; excellent for a basic filter. Purolator and Carquest filters are coming out of the Mann+Hummell empire.
I think OP was referring to the CQ premium and MG select which, as GW posted, are PGI
  • Like
Reactions: GW.
When I search " who makes Carquest oil filters " it states Mann+Hummel. Has there been a change?
MicroGard Select is advertised as 99% @ 25u - could be same as the Carquest Premium but O'Reilly chose to use the 25u spec to be conservative. The guts and media look the same between the two. So it's close to the Carquest Premium. Probably equates close to the 95.5% @ 20u if 99% @ 25u.
Since Advance Auto abandoned CA, its hard to get the CQ51516 filters. I went in to O'Reillys and the counter guy said the replacement was the Microgard 51516, which I bought. Cheap. But its not the "select" variety, and says on the box 3-5K miles. Whats the phycial difference between them, worse filter media?
Likely less efficient and not as robust of build quality. If it matters to you, only the select is manufactured by premium guard.
There are Oreillys all over California.. did you check around for the Select model or did the guy at that one store just ignore it and give you the regular version?
Yeah, that isn’t correct
