Carquest 84712
Does Carquest make a filter same size as the 84712 but just in a longer version?
This filter is for my 2025 Outback, the stock filter that came on the car is about 1/2" longer than the Carquest I bought. I think the Carquest is a great filter, but just wish it was as long as the factory filter.
In the grand scheme of things that 1/2” of filter canister size makes no difference. The actual filter media inside could very well be the same size if you cut open each filter to compare.
And even if the CQP is a little bit smaller than the OEM, it’s still a better option.
  • Like
Reactions: GW.
Subaru OEM filters have been both short and tall, its not unique to the aftermarket:
  • Like
Reactions: GW.
The Pentius XL is basically the same filter as the Carquest Premium. The XL7317 is taller than the Carquest and has even more filter media than the OEM filters.
The only obvious difference between these two filter models is the bypass valve. The Carquest filters have very small bypass valves, maybe too small for the flow rates that Subaru engines are capable of. The Pentius XL has a much larger bypass valve, which seems more appropriate.
  • Like
Reactions: GW.
